| | #41 |
| Moderator Join Date: Jan 2006 Location: The woods of CT
I would have the damaged area welded and either re-tap or insert a heilcoil. It was nice to have finally talked by phone. Call anytime with questions. |
| | #42 |
| Shiraz Join Date: Oct 2006 Location: Virginia Beach
Mike, Starting to think it would be far more cost effective overall to just buy a bike like this one then apply my parts now for a near new bike. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=150319802328&ih=0 05&sspagename=STRK%3AMEBI%3AIT&viewitem= |
| | #43 |
Well, after looking at the cost, I decided to buy a better starter bike. Lucky enough to find this one in NC. Some parts have been taken off since buying it, but this gives a general idea of the condition.
| | #44 |
Somehow along the way I ended up with this free bike. Got about 130 bucks in her and she is running pretty good. Just have to get a title for it now.
| | #45 |
| red dirt girl Join Date: Nov 2006 Location: Cakalaky
Simpson, you need to rent a warehouse! ![]() I think that we just got hold of a '70 K1 Minitrail. At least it doesn't take up much space... |
| | #46 |
| Site Founder Join Date: Jan 2006 Location: Tampa, FL
how exactly do you end up with a free bike? I have to read this. |
| | #48 | |
| Quote:
Do you mean this beauty here??? ![]() She's a hottie, just added pegs, fuel pump, and rear view mirrors... | |
| | #49 |
| Chuck Norris has lost in battle with this Member Join Date: Jan 2006 Location: Massachusetts
I'm not like you much right now ...
| | #50 |
| Banned Join Date: Jun 2008 Location: Saint Joseph Missouri
Good thread, I'll enjoy this one. Ironically, my winter project is a SOHC drag bike, built from a low mile (7000) 74or75 CB750. The one I have had $4000.00+ dumped into it, the owner off'ed himself, and I ended up with the bike, albeit without title. Too many new parts to list, looks like you're covered on that end, if you come across something, let me know and I'll see if I can help. Good project, best of luck to you! |
| | #51 | |
| Quote:
Honda CB750cc sohc Motor Modifications * 750cc bored out 3mm to 812cc. * 11:1 compression ratio. * 29mm Mikuni smoothbore carburetors w/K&N individual filters. * Dyna III electronic ignition. * High energy Andrews coils. * R.C. Engineering aluminum alloy golden rods. * Andrews D grind cam. * Ported and polished combustion chambers. * Balanced pistons with custom designed crowns. * Heavy-duty valve springs. * Reinforced cam towers. * Precision ground 4130 heat-treated alloy cylinder studs. * Custom fabricated 0.5mm aluminum head gasket. * Plus countless hours of grinding and polishing with the trusty old Dremel. | |
| | #53 |
| What about the Creedence Join Date: Sep 2007 Location: Burlington, NC
| | #54 |
| Stare into me... Join Date: Jan 2006 Location: Joisey
| You're probably more discerning than I am but that thing looks like all it needs is a Brillo pad and for somebody to kick start it,
| | #56 |
| Actually I have attablished a painter who paints this particular bike exclusively in VW. Should be mailing out the tank and covers to get painted tomorrow. This weekend I'll hopefully also break the bike down for powdercoat. found a title recovery service to get me a title for the Intruder for a fee. |
| | #57 |
| | #58 |
| Sixty-9er Join Date: Jan 2008 Location: Chicagoland
Does that Intruder have a 1.5 gallon tank or is that just an illusion.
| | #59 |
| Good News for me!
I found a title recovery service and they will charge me 250 clams to get a title. Together with the mech fixes it will be about 400 dollar bike. Originally it was meant to be my girl friends bike, but I see myself putting some miles on it. Should be ready in a couple weeks. |
| | #60 |
| | #61 |
| Status Report
CB750 half stripped... Tanks and all parts getting ready to be painted Ruby Red are at the painters in WV. Planning on powder coating the frame in 1-2 weeks. While the frame is at the powder coat, I'll paint the engine. You can see in the shot the over all discoloration and rust. |
| | #63 |
We used this company to get a title for the DT250 (on JohnnyB's recommendation)- http://www.its-titles.com/15price.htm |
| | #64 | |
| Quote:
dang, thats half the price! | |
| | #65 |
| Test
These pictures are for you Mistermike. I thought you might appreciate one of these items? Can you tell me what they are? |
| | #66 |
Additional pictures to document condition of bike... Getting ready to pull engine for external bling job. |
| | #67 | |
| Quote:
side note: If possible, use a OEM oil filter, some of the aftermarket ones could collapse. Careful not to loose the thin washer which resides between the spring and the filter. Pic #2. Alternator cover. There a one or two locating dowel pins, be sure not to leave them out. | |
| | #68 |
| Pulling the motor is fairly easy. Hope you have a strong back when lifting it out of the frame. Be especially careful when removing the exhaust, don't want to snap those head bolts. You can leave the oil lines attached to the oil tank.
| | #70 |
Hey, Mike, your right these things get big bucks. Mine will be better than average. Because I'm shooting for just under Vic World quality. The fella who ask 30k for his bikes. Here's an outdated list of items I've already bought and have on the NOS shelf. BTW might have to call you soon. I promise the build should start get interesting soon.
| | #71 |
Based on your CB360 work, the CB750 will be a winner. Call anytime...
| | #72 |
HONDA NOS CB750 CB 750 K0-K1 NEW MUFFLER SET 1969-71(200290372713) Honda NOS CB750 Fuel Petcock Valve CB 750 500 550 (220334224434) NOS OEM Honda CB750 Air Cleaner 1969-1978 Models! (220294656260)1 Set of 4 NOS OEM Honda CB750 SOHC Exhaust Clamps! NEW!! (220294660397)1 NEW! CB750 Honda NOS OEM Horn! Beautiful!!!!! (220297813254)1 NOS OEM Honda CB750 Triple Tree Chrome Nut & Washer!!! (220312233553)1 $ Honda CB750 SOHC NOS Mirror Set! Factory New!!! (220331590724)1 New Factory Honda NOS CB750 Front Fender! 1969-1972! (220332428248)1 Honda CB750 Sandcast Chrome Gauge Mounts W/ bushings!! (220332905420) NOS CB750 Grips & Throttle Pipe! Sandcast! 1969! OEM! (220332973391)1 $ Factory Honda NOS CB750 Gas Cap! Fits 1969-1976!! (220332974292)1 New OEM Honda CB750 SOHC Chrome Points Cover!!! (220334059705)1 NOS OEM Honda CB750 Points Plate Complete 1969-1978 !!! (220334261371)1 Factory Honda NOS Tail Light Lens 1969-1971! Sandcast (220334552603)1 Factory Honda CB750 NOS Taillight Base Sandcst 69-71! (220335270925)1 Honda CB750 NOS OEM Shocks! 1969-1978! Beautiful!!! (220335270930)1 Honda SOHC Sandcast CB750 NOS OEM Handlebar! New! (220336256948)1 $ Honda CB750 CB 750 K0 K1 (69-71) - NOS Rear Fender (200291882917) Honda CB750 CB 750 K0-K6 NOS Exhaust Muffler Guard Set (200292150660) Honda CB750 CB 750 NOS Exhaust Muffler Guard Screw Set (350145448922) NOS OEM Honda CB750 Air Box Connecting Tubes! (220329464569) NOS OEM Honda CB750 Cam Chain Guide! 1969-1978! (220336256969) $ Honda CB750 NOS Tank Rubber Set!! (220337557139) $ NOS CB750 Throttle Cable! Sandcast! 1969!! New OEM! (220340886875) Set of 4 NOS OEM Honda CB750 SOHC Carb Insulator! (220341022853) Honda CB125 CB175 CB350 CB450 CB500 CB750 turn switch (350149454777 Honda NOS CB 750 RH Handlebar Switch (110305497148) Honda CB750 FourK0-K6 Side stand kit NEW Sale date: 01/29/09-- Honda CB750 Four K0-K6 Air Cleaner Case Grommet seal Sale 1969 1970 Honda CB750 Four K0 Back Mirror R&L sandcast Honda CB750 Four K0 K1 Rear Fender Bolt Set 1969 1970 Honda CB750 K0 Fuel Tank Emblem set sandcast Sale date 1970 Honda : CB Sale date: 01/19/09 1969 1970 Honda CB750 K0 Absorber Caution sandcast Sale date: 02/05/09 Honda CB750 Oil Housing Sandcast 2ond Design With Ribs Sale date: 02/09/09 Honda CB 750 Four K0 - K6 Getriebedeckel neu 220316263441 - Honda CB 750 Four K 0 - K 6 Stopplichtschalter/Feder 220308860567 - Honda CB 750 Four AufkleberSet neu 220295689345 - |
| | #73 |
Very impressive.
| | #74 |
The tank, side covers, ears and filter are being painted by a guy who paints these CB750 (mostly K0) bikes exclusively. Therefore he understands the the step process of white to silver to red for the special Ruby Red color. Then will apply 4 layers of clear coat. I asked for dripping wet, deep gloss.
| | #75 |
Just placed an order with Bikebandit for nearly 2/3 of all hardware on the bike for nuts and bolts. I'm talking Honda OEM in red tag bag stuff. Plus I have a line on a guy in CA who reconditions the tach and speedo to near NOS condition. I simply trade my set in (core) and exchange money. |
| | #76 |
How is the painter going to duplicate the large gold stripe on the tank?
| | #77 |
As much as I appreciate the original Phillips head screws, they are a PIA when trying to remove them. A impact driver is a must. I still have a bunch of them if to need any.
| | #78 |
He will use a decal set and clear coat over. He explained the entire process to me. I forgot most. The tank will be boiled out and given a new liner for good measure. I've got a couple cracks in the covers. He said they would be cut out to stop the cracking and plastic welded.
| | #79 |
The impact was a must on the CB360, probably have to pull it out of retirement for another mission. I've ordered all new replacement engine covers including valve cover head, alternator, transmission, and points. Still can't find a sprocket cover in the states. Might have to order one from a over seas UK parts dealer.
| | #80 |
Forgot to mention: Examine the head gasket for oil leaks(common). It can be replaced fairly easy when the motor is out. Impossible when the motor is in the frame.
