| | #81 |
| Shiraz Join Date: Oct 2006 Location: Virginia Beach
thanks to hondaf4iguy, the engine is out! Not a light engine, It definitely weighs 197 lbs. Now to begin a massive cleaning, stripping and painting operation. |
| | #82 |
| Flat you Lance Join Date: Jun 2007 Location: San jose
The famous golf ball engine stand.
| | #83 |
| Moderator Join Date: Jan 2006 Location: The woods of CT
Hey Simpson, the 750 motor does not like to be resting in that position. Get a milk crate and set it in there like it was mounted in the frame.
| | #84 |
I took five minutes to strip the bottom of the engine. I'm on my 3rd can of shop size carb cleaner. The old chain oiler has coated everything with a thick nasty crust of dirt and old oil. Yes that's my custom engine stand! |
| | #85 |
| | #86 |
| Hastatus Prior Join Date: Apr 2007 Location: vermont
how would u like to be laid on your face all day HRMMMMMMMMMM?
| | #87 |
| | #88 |
| Dabbling with ceramic engine paint... |
| | #89 |
| Tirone Choolaces Join Date: Aug 2007 Location: Southern Maryland, USA
That looks great...dabble on
| | #90 |
What procedure do you have for the valve cover and other oxidized parts? These parts had some type of plastic coating. I use to soak them in commercial carburetor cleaner, then glass bead blasting. Polishing was optional.
| | #91 |
| | #92 |
| | #93 |
| | #94 |
| Auction over... He obviously wanted $10k.
| | #95 | |
| Quote:
Now Vic can do a nice looking build! I've just about worn these pictures out... | |
| | #96 |
babbitsonline can go suck a nutty poo stick! They screwed me out of a cylinder cover, which dont exactly grow on trees. |
| | #97 |
I need an NOS Cylinder cover!!!! Help!!!!!!!!!!!
| | #99 |
interesting alternative... thx nos still on the radar |
| | #100 |
| Woohoo!!! Found a NOS cylinder cover here! http://www.westernhillshondayamaha.com/ After an exhaustive search... |
| | #101 |
Engine painted awaiting all new engine screws from bike bandit and new NOS cylinder cover my new parts source. |
| | #102 |
Good find! *A most important item for the NOS valve cover is the OIL SEAL P/N91256-096-651 for the tach drive. * Also 8 new 'O' rings for the valve caps O-RING (30.8MM) 91302-001-020 |
| | #103 |
Did you inspect the area between the head and the cylinders for trace signs of oil? Now is the time to replace the head gasket if need be.
| | #104 | |
| Quote:
Always spot on! Fortunately I was thinking ahead from learning on the CB360. Those tach seals always leak! All of the above parts are coming new from Bike bandit, including new tappet covers. | |
| | #105 | |
| Quote:
Just a puff of intermittent smoke we talked about. THe engine sounded real smooth. | |
| | #106 | |
| Quote:
Items keep popping into the memory. Do you have a multi 4 cylinder carb. sync. tool (monameter) with (4) 5 x 0.8mm adapters? A must have!!! Last edited by MisterMike; 02-19-2009 at 10:44 AM. Reason: edit: revised adapter threads | |
| | #107 | |
| Quote:
Wish I had sent you a picture before painting.. rats! I "feel" pretty good about any oil leaks around the head. No sync tool... Will need one soon. Ideas? Rims are starting to look good with detail cleaning to the point I don't intend to get replacements or re-lace. | |
| | #108 |
| Carb tuner
It appears the low price mercury models made by MotionPro are no longer available. Hg(mercury is toxic). You might get lucky and find one otherwise the new MotionPro is one source. The best price was from bansheestuff.com Another option is the Morgan Carbtune II. This is the one I use. |
| | #109 |
Parts ready for powder coat after an awesome Sunday of play in the garage. Oh the music and heater was cranking... |
| | #111 |
It's amazing to see how far frame technology has evolved.
| | #112 |
I was amazed to see the silver paint match perfectly to orignal when taking off the cylinder cover. The paint inside/around the cam chain is orignal and of course the outside is my paint job.
| | #113 |
Just a quick look with new cylinder cover in place. |
| | #114 |
| I'm going riding. Join Date: Jul 2008 Location: Walcott, ND
I'm enjoying watching this progress i have a 71 750 that came somewhat stock with the normal terrible wiring and crusty tank... the motor is almost back together, i have my fairings, and now i can't decide if i should update some suspension doo-dads or not... it's become far more of a streetfighter/rocket/bastardization than your immaculate restoration though! i'm impressed!
| | #115 |
| What about the Creedence Join Date: Sep 2007 Location: Burlington, NC
| | #116 |
| I am BATMAN!!! Join Date: Apr 2006 Location: Ft. Collins CO
Good work, keep the pics coming!
| | #117 |
| red dirt girl Join Date: Nov 2006 Location: Cakalaky
Really enjoying following your progress, Simpson.
| | #118 |
| Sneak Peeks
Few more, of me just working on the detailing. The bags are of course all of the replacement hardware. |
| | #120 |
Look closely at the center photo lower right. The gear shift assembly to be exact. The Honda engineers had too much saki when this mechanism was designed. It is commonly referred to as a 'rube goldburg' Final test for wannabee CB750 mechanics was to correctly complete the re-assembly.Just a little vintage trivia! |
