Motorcycle Forum
Forum Twitter Forum Twitter Forum Twitter Website Twitter
LinkBack Thread Tools Display Modes
Old 07-02-2009, 10:04 PM   #1
Front Brake Slide
I was out in the country working on some basics and practicing stopping quickly. Under heavy braking, the front just wants to slide. On my bro-in-law's 600rr, it just does stoppies, but on my 919, it just wants to dive and slide.
So...is this a flaw, better than a stoppie, or what? I'd almost rather go into a stoppie as opposed to the front locking and sliding.
Remove Advertisements
Old 07-02-2009, 10:18 PM   #2
try some fork springs to increase the strength of the front end to avoid serious diving. or if you have the money send the forks off to get reworked.
Old 07-02-2009, 10:23 PM   #3
I killed Barton664
Basspiece919's Avatar
Hmmm... I have 20k miles on my forks and they are way mushy (not for long Racetechs en route) but I have absolutely no problem doing stoppies... What kind of tires do you have on it?
Old 07-02-2009, 10:24 PM   #4
and a new front tire?
mine stoppies....... really well.
Old 07-03-2009, 04:00 AM   #5
Keep practicing. You need to modulate the front until the nose dives, transfer your weight forward, and then you can add more front brake. It's sliding because there's not enough weight on it and too much front brake.
You'll also learn to let off the brake real quick when the front starts to lock, or you'll find yourself tucking the front and posting about used parts available.
Old 07-03-2009, 05:46 AM   #6
Pilot Road 2 are my current tires. It seems like the front wants to slide more and the rear wants to spin more than the Pilot Power tires I took off.
I'm learning when the front want to try to lock out in the boonies so I hopefully don't do that in a real emergency situation.
Old 07-03-2009, 06:06 AM   #7
soundman's Avatar
Check your pressures. A lot also depends on road surface, temp, are you progressively applying or just grabbing a handful. One thing about brakes is that their consistency is inconsistent.
Old 07-03-2009, 06:16 AM   #8
you are driving on asphalt and not dirt roads??? right???
Old 07-03-2009, 07:42 AM   #9
Air pressure is checked almost every day and kept at 34 PSI front and 39 PSI rear. I tried a few "oh crap" grab a hand full and that is when it slid. When applying a little more smoothly, the front seems to load up and just stop. But man does this thing dive hard. Obviously not a surprise to anyone who has an unmodified '02 or '03 front end.
I might not have teeth or wear shoes, but at least our wagon trails are paved.
Old 07-03-2009, 09:02 AM   #10
I'm going riding.
scrat's Avatar
my niner has never been too fond of stoppies...it will do it, but takes some pushin and carefull squeezing. the RC on the other hand seems to want to throw me over the front all the time... it's pretty crazy. i'm going to go put my new BIGGER BRAKES on it now
Old 07-03-2009, 11:21 AM   #11
maybe you should make air pressure lower
Old 07-03-2009, 11:25 AM   #12
919>food>beer
Jeef's Avatar
Its no suprise its locking up, grabbing a large hand full of brake is never advised, you need to modulate it on, as the weight moves forward the more pressure you can put on the lever.
Old 07-03-2009, 05:24 PM   #13
dude ... put a set of racetech springs on the front i guarantee stoppies....
those springs make the brakes work scary good...
Old 07-03-2009, 05:48 PM   #14
Shaughnessy's Avatar
I would say you are running with old rubber. My Road 2's held up great until the last 1,000 miles and felt greasy. I would say you are either high on mileage, had them on for about 3 years, or they were manufactured more than 3 years ago. Rubber, especially soft compound rubber like motorcycle tires, has only a 3 year shelf life before the rubber starts to harden and does not stick as well.
Old 07-03-2009, 05:53 PM   #15
i guess i better check the date on that big box of condoms then....
Old 07-03-2009, 11:58 PM   #16
Adventurer
Better to modulate than never...
Old 07-04-2009, 07:31 AM   #17
I checked the date codes on the tires and they are good. Front was made the 39th week of '08 and the rear was made the 40th week of '08. I mounted the front when it was only 4 or 5 months old. the rear was about 10 months.
The 919 must have just so much power and torque that it will melt a rear tire. No wonder it's easy to beat a 600RR.
The two times it slid, I just grabbed a handful. By modulate, do you mean grab progressively larger amounts of front brake or pulse them?
Old 07-04-2009, 07:56 AM   #18
donation 10/27/09
drewvir's Avatar
sqeeze don't grab you gotta let the forks dive a 'bit b4 really gettin' on them.kinda hard to describe
btw helps if the jewels are on the tank.
Old 07-04-2009, 08:18 AM   #19
Hastatus Prior
3dcycle's Avatar
helps what? that has never helped me do anything
Old 07-04-2009, 09:40 AM   #20
donation 10/27/09
drewvir's Avatar
if he sits up by the tank it'll change the weight distribution
Old 07-04-2009, 10:59 AM   #21
919>food>beer
Jeef's Avatar
yeah that, you should notice as the front end loads up and weight shifts forward you can keep adding more and more pressure to the lever. Thats actually why MSF teaches to not cover the brake lever, to keep you from grabbing a gaint handfull.
Old 07-06-2009, 04:28 PM   #22
touring919's Avatar
Wouldn't one grab a big handfull when they are actually grabing for it as apossed to having one finger already there than can squeeze. And even if it doesn "grab" the brakes, one finger isn't going to do much until its friends join in latter after some weight transfer as already occurred. Just being the devels advocate on this one, I rarely cover my brakes. Only in city traffic when i see something I don't trust do I cover.
Mine locks up alot. Depends on the what road, if the forks bottom out and of coarse that particular roads conditions and how settled the chassis is before I really start pulling on that lever.
Getting it to stopie is easy enough if you move your weight in a way that instigates a stopie.
The 919 is more prone to slide than an RR but way less than any cruiser. Or sport tourer. Its just the nature of this particular beast.
Twitter Facebook
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0 ©2009, Crawlability, Inc.
